rfernandez said:the FC200 Camera update has been put back on...
gpauk said:rfernandez said:the FC200 Camera update has been put back on...
Only v1.1.9 from 20/1/14 seems to be there -- where are you seeing v1.1.99?
gpauk said:That gets a 404 error for me...
...._firmware_v1.1.9.zip works.
garygid said:Can anyone do a file compare to see if this 1.1.9 is the same as the older 1.1.9, please?
If it is the same, nothing has changed.
If different, it is really poor form to have posted two different 1.1.9 versions.
Is the file date the same?
so.... does this mean we should update the camera again???gpauk said:garygid said:Can anyone do a file compare to see if this 1.1.9 is the same as the older 1.1.9, please?
Loaded both files in ultracompare... There are quite a few differences. That is, as you say, naughty.....
AllanVB said:so.... does this mean we should update the camera again???gpauk said:garygid said:Can anyone do a file compare to see if this 1.1.9 is the same as the older 1.1.9, please?
gpauk said:Does anyone have a copy of the 1.1.99 zip file? I'd be interested to compare that to the latest 1.1.9....
Installed this version on my new P2V (Ver. 1.4) that arrived today without issue. Making sure to Format the memory card in the Vision Camera via the Vision App on the iPhone. This format did create a DCIM folder that I left intact and just copied the firmware.bin file with it in the root of the card. Returned the card to the camera, turned it on and the update took about 20 seconds to complete. All camera functions appear normal.dcozad said:Please report results if you have installed the 1/26/14 version.
I had a quick look at it and nothing major that I could see, maybe a few graphic changes and updated QR codes.dcozad said:Anyone done a comparison of the 1/27/14 Vision Manual????
