AnselA said:
j69chevelle said:
So it still works I'm just a moron and was doing the wrong programming sequence. In order to change the Home Point and not the Course Lock direction you have to cycle through all three positions (Off through Home Lock) on the IOC switch 5x. Both Home Lock and RTH /Failsafe features were tested successfully. Thanks guys!
But did you test Dynamic Home Point?
I did, both HL and RTH went to the launch location...
I did test Dynamic Home Point and it works perfectly. Ensure you have the latest update for the Vision App. Make sure your GPS feature is ON in your mobile device than activate the Vision app. Once in the app turn on Dynamic Home Point in the settings menu. When Dynamic Home Point is active you should see a green circle highlighting the compass (not the correct nomenclature) in the bottom left corner of the FPV (camera) view. Hope that helps
So the exact procedure I went through was quickly cycling through the "Off", "CL" and "HL" positions on the IOC switch 5x. I left in in the HL position for approximately 10 seconds. The aft status lights also rapidly blinked green which is what I would expect it to do once it has established a new home point. I turned the IOC off than I proceeded to place the copter 40 meters away and offset to test the HL. It worked. The new HL point had been programmed successfully. Than flew the copter to my location and turned on the Failsafe switch and it flew to the new RTH point with no issues.
I still wasn't following the correct programming procedure so N017RW locked me on to the correct procedure: HL / RTH point programming - Cycle through CL and HL positions on the IOC (S2) switch 3 - 5 x rapidly. I also found it helpful to end the sequence in the HL position and let it set until after the aft status lights are done blinking. Programming complete. Use HL position to verify. So long as Dynamic Home Point is turned off, when you activate Failsafe / RTH mode it should go to your newly programmed point.
