New drone - need help
Discussion in 'Phantom 2 Discussion' started by sb in gp, Dec 27, 2015.
  1. sb in gp
    Michigan
    New to drones. My brother in law gave me a used phantom with no accessories. Some scratches, but overall an 8 out of 10. How can I tell what I have? It says pv-330 on the tag. I need a charger, camera and a remote. Not looking to spend a ton, but I'd like to use for some video. Open to advice. Thanks.
  2. jason
    Commerce Twp,MI
    Lets start with the controller. Turn it over and see what frequency is printed on the label should be 2.4Ghz. Does it have a battery that looks like this? If the answer is yes to both then it's a stripped down Phantom 2 Non Vision.
  3. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
    This link will show you the different Phantom models. Scroll down for the Phantom 2 versions - Phantom Series - Intelligent Drones | DJI
  4. PhantompilotNL
    DJI PHANTOM 2 PV330 PHANTOM DRONE W/CAMERA, PVT581 CONTROLLER, & RE700 EXTENDER
    Is wat i found on ebay for the picture...
    I see its a phantom vision 2 ( not the plus) with 5.8 ghz controller. What i remember has the inside connections for a gimball and video The gopro uses 2,4 ghz so you can use the wifi of the gopro ! with this bird.
    Just by the gopro 4 black or other , use that wifi of the cam which is possible for this bird and and have fun.
  5. LuvMyTJ
    Staff Member
    Does it look like this? If so it is the P2 Vision
    [​IMG]
    If so here are the details for it - Phantom 2 Vision - DJI Wiki
    If it looks like this then it is the P2 Vison +
    [​IMG]
    If so, the details are here - Phantom 2 Vision+
  6. PhantompilotNL
    So dont buy any controller, just the 5.8 ghz.(mod number pvt 581)
  7. PhantompilotNL
    Best is to open the body and make a picture....in both cases the battery and the remote are the same... :)
  8. sb in gp
    Michigan
    No controller. Yes the battery looks like that. Thanks.
  9. jason
    Commerce Twp,MI
    Is there an 8 pin cable and connector coming out the rear leg??
  10. jason
    Commerce Twp,MI
    Without a controller there is only one way to really tell which P2 you have and that is by opening the shell and checking which receiver board is inside. The board itself is under the main board and can be seen through the battery compartment. Here are two photos of both boards.
    2.4GHZ receiver.JPG 2.4GHz receiver
    5.8GHz receiver.jpg 5.8 GHz receiver
  11. sb in gp
    Michigan
    I don't see an 8 pin connector. It has a little 3 wire connector (yellow, red, purple) and what look like a white audio connector. Assume this is the camera connector. It has a camera bracket, but no camera.
    Here are some pics:
  12. sb in gp
    Michigan
    Thanks. I'll open it up and report back.
  13. jason
    Commerce Twp,MI
    You will need to open the shell in order to identify which P2 you by comparing the above photos in post #10.
  14. jason
    Commerce Twp,MI
    Those allen screws are metric.
  15. sb in gp
    Michigan
    Thanks everyone. Your help is much appreciated. Looking into the battery bay, I can see that I have the 5.8 card based on the way the grey wires are situated.
    So what is the general recommendation? Take to hobby shop and test it, or just order a charger and controller and go?
    Scott
  16. jason
    Commerce Twp,MI
    Scott you'll need to open up the shell because both boards have the same antenna setup look at those photos they do not use the same components. I also mark each as what frequency they are.
  17. PhantompilotNL
    Based upon earlier info and my experiencebbuy the controller , props and battery and you can fly. Second hand?
  18. jason
    Commerce Twp,MI
    The OP doesn't have clue as to which controller he needs until he actually opens the shell.
  19. sb in gp
    Michigan
    OP will open to make sure. Thanks. I'll report back.
  20. sb in gp
    Michigan
    Brother in law has a bunch of rental properties. Occasionally he inherits stuff when tenants leave under unusual circumstances. This drone was almost thrown out. It's a little abused but salvageable.
Similar Threads - drone need help Forum Date
New to drones. Need camera help. Phantom 4 Pro Help Dec 30, 2017
Standard Need Help About My Drone :( Phantom 3 Help Dec 6, 2017
Hi all, new pilot here that needs help with beginner drone photography - Video compilation Standard Nov 8, 2017
Need help drone wont connect Phantom 4 Pro Help Oct 9, 2017
Need help upgrading P3A!!! The drone motors won't start after upgrade Pro/Adv Discussion Aug 12, 2017
