New DJI Charging Hub for P3 Batteries...
Discussion in 'Pro/Adv Discussion' started by TAZ, Aug 13, 2015.
  1. TAZ
    TAZ
    Now that the new Charging Hub for P3 batteries is available from DJI: http://goo.gl/HjH2wD I'm pretty excited. Holly cow, $90! That's far and above anything I've seen out there both in price and functionality.
    I'm curious though...does anyone have any insight as to considerations in regards to a car inverter? I know I'm asking for a lot...wanna connect 4 batteries while I'm driving down the road. Anything I'd be well served to consider. On its own it sounds great!
  2. acherman
    Alberta, Canada
    I am considering this based alone on not having to look on the backseat to see if one battery is done so I can plug in the next one. Plus it looks a lot better/safer than the 3-battery eBay strip. That said, there are plenty of threads about inverters here already. Some are working on 12 VDC cig lighter solutions as well.
  3. bobmyers
    San Antonio, TX
    Got this one in a couple of days ago-- 3 Batteries in the time that it takes to charge one. best for the buck that I have seen or used. I have the strips -- but they take 3.5 to 4 hours for 3 batteries.
    https://www.rcdepothobbies.com/Charger_for_DJI_Phantom_3_charging_3_batteries_and_p/rcdh-dji025.htm
  4. acherman
    Alberta, Canada
    I'm torn on that one too. Haha Just because it charges a single battery slower than the factory (lower current rating). I'm just never happy. Plus, for me, I am on a quest to go to 12 VDC power. But I'm almost tempted to order that one just for the battery side cables/connectors since I can't seem to find them anywhere.
  5. bobmyers
    San Antonio, TX
    Now there is an idea? Maybe someone will start selling just the cables.
  6. TAZ
    TAZ
    For sure in regards to info in general in regards to inverters. I was more interested in whether there were additional considerations in regards to this device. I already have an inverter that doesn't work great (underpowered). Just wondering if anyone had any insight as to if the this hardware itself changed what one might consider.
  7. acherman
    Alberta, Canada
    I actually ordered the cable and connector that goes inside the P3 to start with. I wish we could find out the manufacturer of the charger you got and see if they sell just the cables. The labels seem lacking though.
  8. acherman
    Alberta, Canada
    Try to find a true sine wave inverter. There is the possibility that the modified sine wave won't be an issue since we're just supplying voltage with the factory "charger" (the charging circuitry is built into the smart battery), but at $150 USD, I would rather take good care of them. And find one that has a capacity for twice what you're going to use it for. They work much better (and cooler) at half load than at almost full load.
  9. bobmyers
    San Antonio, TX
    There is nothing on the labels that identifies the manufacturer-- I just looked-- probably some one room operation somewhere in China-- may even be some patent infringement issues with DJI so the don't want to put a name on it.
    acherman likes this.
  10. 4wd
    4wd
    North York Moors
    If it's charging multiple batteries faster than one at a time it's going to draw more power.
  11. JayB
    Nottingham UK
    I don't have any real world experience but I've been researching which way to go with regard to an inverter and a 300w Pure sine inverter IMO seems the best option. Pure sine basically gives you the same alternating current as your supply at home. In one case it was reported that by using a modified sine wave inverter it actually damaging a laptop battery after a few months and it would no longer hold a charge. There is lots of information out there usually in relation to RVs and boats. Pure sine inverters are usually 3 to 4 times more expensive than a modified inverter so beware of cheap inverters on eBay, or anywhere else for that matter, claiming to be pure sine.
  12. aludden
  13. acherman
    Alberta, Canada
    Haven't tried it, but I have watched them for a while. They probably work fine. Personally, it's not for me - only 70W = slower charging for really low batteries, and I don't like how the cable hangs off the side.
  14. aludden
    Yeah, it's not something I would use all the time, but I could see me wishing I had one in my bag at some point. An extra opportunity to fly if I'm traveling somewhere and driving all day.
    The stock charger is just dumb, right? The smarts are in the batteries? So as long as this provides the power it would be OK?
    Thanks!
    Alex
  15. acherman
    Alberta, Canada
    Yup, just gotta give it 16-17VDC and the "intelligent" battery does the rest.
Similar Threads - DJI Charging Hub Forum Date
DJI Charging Hub Phantom 4 Pro Discussion Feb 6, 2017
DJI Intelligent Flight Battery Charging Hub Classifieds Jan 22, 2017
DJI Phantom 4 with 4 batteries, HDMI Board, Battery Charging Hub in Original Box Classifieds Sep 28, 2016
DJI's New Promo - Phantom 4 with 2 Extra Batteries with Charging Hub or Car Charger for $1,399 Phantom 4 Discussion Aug 6, 2016
DJI Battery Charging Hub for Phantom 3 Quadcopter (NIB) Classifieds Jul 23, 2016
