Has anyone tried to bind the new radio/Tx (new camera control wheel) with a P2, not Vision? I cannot get it to pair/bind. Thx much.
DJIquadzilla said:I have a p2 v2 non vision and hd-3d gimbal works perfect with wheel
bschaub said:I have the 5.8 new radio. DJIquadzilla, what procedure did you use to bind the P2 V2?
jsob said:I saw this thread and I was curious to see if anyone has experience with linking the new tilt wheel controller to a P2 V1? the reason I ask is because I bought the new controller and used DJI's procedure to link it. However after pressing the link indicator LED/link button on the P2 to initiate the linking procedure the link LED starts out flashing red and then after the TX is turned on the LED goes out instead of turning solid green to indicate it is linked successfully. I tested the P2 with the props off and it responds properly to the new remote but I was a little nervous to fly because I thought that the link indicator LED/link button should be solid green when linked to the TX properly.
ianwood said:bschaub said:I have the 5.8 new radio. DJIquadzilla, what procedure did you use to bind the P2 V2?
A 5.8GHz radio will not bind with the non-vision P2 as it is 2.4GHz.
