  1. xgaul
    I took advantage of the Apple deal and got 2 new batteries, they are the newer ones with brighter LED and that's all fine BUT..
    I don't feel they fit properly. What I mean by that is they click in when pushed in. But they also move a little bit. If you push down on the battery a small gap develops between body and battery.
    The battery won't pop out unless you push both release tabs BUT my concern is the wiggle and gap because of the fact another member on here had an issue where he can easily pull the battery out.
    Any insight? Anyone having similar experiences? Batteries do make a STRONG click sound when pushing into the body so it makes me think they are secure but I worry because I do long distance flights
  2. Stealthmatt
    Not sure if you have the same issue, but a guy reported his battery wouldnt stay in.
    New Battery from DJI doesn't set properly
    When you try to take the battery out, do you only lightly have to touch the tabs or push it right in?
  3. xgaul
    No I have to squeeze the tabs to pull it out. And it makes a loud loud click when pushing in
  4. xgaul
  5. Jussaguy
    I didn't see this thread and started one with the same issue.
    Please mods, either delete or merge my thread, thank you. "Battery Wiggles" is the name.
  6. Start Visit
    I ordered from DJI with 2 extra bat deal. no issues. only having hard time to pull it out unless Im holding P4 in the air.
Similar Threads - battery problem Forum Date
P3 battery problem and motor overload Standard Wednesday at 10:20 PM
From Transmitter Battery Problem to No Firmware Phantom 4 Help Dec 10, 2017
GL300C RC battery problem - doesn't fully charge; fast discharge Pro/Adv Discussion Dec 9, 2017
Start a New Conversation: Phantom 2 naza software and battery problem? Phantom 2 Help Nov 10, 2017
Battery problem... 2nd opinion General Discussion Sep 20, 2017
