New 5.8 transmitter observations/Trainer Port Compatibility
Discussion in 'Phantom 2 Vision + Discussion' started by paulsluxmd, Nov 1, 2014.
  1. paulsluxmd
    I received the new 5.8 transmitter and performed latest updated from 10/31 on both the controller and Phantom Vision 2 plus.
    Two Observations:
    1. The camera title lever works great. The green light on the camera mount now flashes green instead of a solid green light when the camera is connected.
    2. The 4 LED's that indicate battery level for the rechargeable LiPo originally worked, but now do not work after first charging. They are just blank and do not light up.
    The controller charges and the main green light turns on, as well as the controller works okay. Any thoughts on this one??
    3. I plugged the trainer port of the new transmitter into my Phoenix RC 5.0 simulator USB (which has a Vision 2 model) and the program DOES NOT recognize the DJI remote.
    Does anyone know/have a trainer program that allows the use of the Phantom 5.8 controller or know how to get it to be recognized???
  2. Mori55
    NJ-USA
    Re: New 5.8 transmitter observations/Trainer Port Compatibil
    How do you bind the new transmitter ?
  3. Dirty Bird
    Glen Burnie, MD - USA
    Just power on the Phantom, look underneath and you will see a blinking red light. Use a paper clip and press the button in the hole, then power up the new transmitter and it will bind. The red light will stop flashing when it successfully binds.
  4. Mori55
    NJ-USA
    Thanks !!
  5. jaywoodz
    How did yup update the remote?
  6. jaywoodz
    I updated the remote.. now the LED's on the remote are gone, won't shine green or anything. Camera pitch control on the remote still doesn't work. I'm terrified to fly this POS. All these updates have ruined everyones weekend. We're all scrambling to try and fix this.
  7. Fantomas
    What simulation program is compatible with the new "Trainer Port" ????
    I looked everywhere and found nothing :-(
  8. garrock
    Portsmouth Ohio USA
    About the Trainer Port:
    • If you have an oscilloscope, then try viewing the waveform.
      That will also tell you the voltage level of the digital signal.
      Also, which pin of the connector has the signal and which pin is ground.
    Question:
    • Is the new DJI trainer port a simple looking 3.5mm jack? (like used for headphones; two or three wire?)
  9. flyNfrank
    Indy, USA
    Isn't the Trainer feature itself on hold until future release in an upcoming update?
Similar Threads - transmitter observations Trainer Forum Date
Multible FPV goggle on 1 transmitter Phantom 4 Help Jul 28, 2017
Standard Can I link 2 transmitters Phantom 3 Help Jul 27, 2017
Tripod for P4 Transmitter Phantom 4 Pro Discussion Jul 23, 2017
Dji avl58 transmitter and elvid skyvision help please. FPV (First Person View) Jul 22, 2017
DJI Phantom 3 4K transmitter, props, charger, Canada shipping only Classifieds Jul 8, 2017
