never ending "warm up" after upgrade
Discussion in 'Phantom 2 Help' started by crchisholm, Jun 10, 2014.
  1. crchisholm
    St Petersburg, Florida
    After I installed the newest version of the assistant software (v3) and upgraded the firmware on my phantom 2, it does not seem to work. When I turn the quad on, it goes into the red-green-yellow sequence as if warming up, but never gets beyond that point. It just keeps flashing that same sequence.
    Has anyone else had this happen? Any ideas about what I can try?
  2. Big Ben
  3. crchisholm
    When I do the advanced IMU calibration, it seems to go on for ever as well. I finally cut it off after two hours. As far as I can tell, that is the only thing to try with this light sequence.
    Anybody got any other ideas? I really want to get back into the air.
    Thanks in advance.
  4. tanasit
    The 3 color led could also mean the IMU abnormal data.
    Check the receiver type, sometime the upgrade changes that to the wrong one.
    Good luck
  5. crchisholm
    SOLUTION: I uninstalled the assistent software, removed the DJI Prodocts folder, downloaded it again, and ran the advanced callibration and this time it ran and completed correctly. I tested the quad and it is back to normal. I actually think it's more stable than it was. I'm a happy guy. Because I deleted the whole folder, I will have to download the drivers if I ever need them again but that's not likely.
    Life is good.
    Thank you all for your suggestions.
    Charlie
Similar Threads - never ending warm Forum Date
This is why you should never ever upload 1080 HD General Discussion Dec 23, 2017
Never buy DJI drones - A nightmare with Phantom products Off Topic Dec 17, 2017
My Pro+ Never Returned Home After Losing Signal? Just disappeared Phantom 4 Pro Help Dec 6, 2017
Bet you never seen DJI drones this low on price before General Discussion Nov 10, 2017
Start Diagnostics never finish Standard Oct 21, 2017
