Need some Help
Discussion in 'Pro/Adv Discussion' started by badawgie71, Mar 20, 2016.
  1. badawgie71
    Ok, so I have a new P3P, I've had one before just got a good deal on a newer model so I bought it..Brand New.
    My problem is that I installed the update and it goes just fine. it completes its cycle and I turn it off and restart. When I do I get a repeating 2 beep sound and no signal on my tablet. The radio light is green and I can move the gimbal up and down with the knob. When I go into the GoApp to check the status of the firmware it shows the app firmware installed but nothing from the P3P......
    Any ideas?
  2. alokbhargava
    San Francisco, CA
    Did you keep RC off during FW installation on P3?
  3. badawgie71
    yes the rc was on the charge
  4. badawgie71
    all i have is repeating beep beep, and flashing lights red,yellow,green
  5. badawgie71
    yes i had it on the charger
  6. alokbhargava
    San Francisco, CA
    Unable to figure out what did you miss in the procedure?
  7. RedHotPoker
    Edmonton Alberta
    Format the sd card in the drone and place the card back in the computer, replace the correct bin file back on the clean sd card and start the update process in the drone over.
    RedHotPoker
  8. badawgie71
    I've done this just like all the others, Its just odd that when I open the app I don't get an image, and when I go into the settings to see what firmware are installed I see the app, but I see no firmware for the quad or the radio. What even has me more confused is I know the raido and craft are linked because the gimbal will tilt?
  9. badawgie71
    I tried that it wouldn't let me format from the app
  10. badawgie71
    FYI 1.04 was installed on the new quad, I installed 1.05 and was just gonna go up in order to 1.06 to be safe.
  11. badawgie71
    You know what..... when did we stop using the sd card to update the radios? 1.04 or 1.05?
  12. alokbhargava
    San Francisco, CA
    I think after rebooting everything and reestablishing connections and waiting for sometime, all will return back. In my case I had also seen missing FW versions on dpi App but they appeared at some point of time, I don't recollect when.
  13. alokbhargava
    San Francisco, CA
    From 1.4 onwards.
  14. badawgie71
    Well that doesn't seem to help then. dang it. figures an original pro, and advance and a inspire......no issues.
    Get a new model P3 and having all kinds of issues.........
  15. El Conquistador
    Have you had any progress with this yet? My p3p stopped sending info to my tablet also. No clues as to why. No updates or anything. Worked perfectly one day and stopped working the next.
  16. rich146
    I'm running fw 1.1.9 and managed to update the radio without SD .
Similar Threads - Need Help Forum Date
Just starting need help Phantom SE Jan 11, 2018
Need help with Phantom 3 Standard Standard Jan 8, 2018
Need help with Pano Mode Phantom 4 Pro Help Jan 3, 2018
Flight distance maxed at 500 meters. Need help. Phantom SE Dec 30, 2017
New to drones. Need camera help. Phantom 4 Pro Help Dec 30, 2017
