need P2 upgrade advice
Discussion in 'Phantom 2 Discussion' started by 2kvfr800, Jan 14, 2015.
  1. 2kvfr800
    Hey guys,
    Have a DSLRPros ultimate cinema edition quadcopter that got damaged.(P1)
    So i replaced it with a P2 with a H3-3d gimble.
    With the stock transmitter, and P2 firmware updated, it wants to do its own thing. i take off and it just keeps going and is very erratic and mostly unresponsive.
    I want to put the T8FGS in the P2 ( found the tutorial for that!)
    The P1 has a NAZA (multirotor V2)
    The P2 has a NAZA Phantom (??) not sure what version this is..
    I want to add DJI ground station to the p2 as well
    the P1 also has a circuit board marked FBOSD V1.2 is this a first generation iOSD ? should i transfer this or get a iOSD mini?
    Should i swap out the NAZA V2 from the P1 and put it in the P2 ?
    Any help anyone can give me would be awesome.
    also if you know of any tutorials or guides on how to swap and/or reprogram the Naza
    what do you guys recommend i do? and where is the best place to buy stuff?
    Thanks, Joe
  2. 2kvfr800
    What would you do?
    I want the Phantom 2 to have the gopro h3-3d ground station etc
    the phantom 1 will be for play..
    If i swap naza, do i put plugs in same position? is there a guide for that?
    Thanks in advance..
    [attachment=1]
  3. 2kvfr800
    48 views in a day and no responses. this is depressing. Another guy with fly away problems get 13 responses in 3 hours
  4. Crazykaktus
    Hehe don't worry, I think its because most people don't quite know what to say... May I ask one quick question. Have you done a correct calibration of your Compass and then have you reset and recalibrated the IMU ? Mine went on it own mission and would even start circling once take off - did a compass reset and the recalibrated away from any metal structures and power lines.... did an advanced IMU recalibration and it sorted 90% of my issues... Drone was much more stable. Basically the NAZA in the 2 should be better than the 1. So I won't just swap the two out... Try it first by resetting and calibrating the basics....
    Sadly im not that familiar with the circuitry inside the P1 as I have never had one so I am unable to advise
  5. PhantomFanatic
    USA, GA
    Why didn't you help???
    As for me, no I don't fully understand what was being asked. And, I haven't opened my bird and I will try not to until the warranty expires. So, I'm sorry, but I hope someone will have an answer for you. Good luck.
  6. spudraleigh
    San Diego, CA
    Interesting that you call yourself "PhantomFanatic" and yet you haven't opened it up :? But the point is, by your post you give the false impression that opening your "bird" will somehow influence your warranty. This has been discussed at length on this forum and the consensus, based on research and close examination of the DJI warranty docs, is that as long as you are installing or modifying the device per DJI instructions or for other appropriate reasons, your warranty still holds. Of course if you don't know WTF you're doing and you horribly damage it then your warranty might not be useful ;)
    I mean, how could you possibly install a LightBridge, AVL58 or ios without working on the insides and why would DJI provide instructions and videos telling you how to do so? Just my $0.02... As always, as we used to say on the Interwebs, YMMV :)
    P.S. I also did not help!
  7. 2kvfr800
    Because if I'm having flyaway issues, how can i help if I'm asking for help with a similar issue? I have grounded my phantoms until i can figure out what to do.
  8. Crazykaktus
    Uhhhhh Opening your unit does not void your warranty, if it did they wouldnt sell you a H3 3D gimbal or iOS mini with USER INSTALL INSTRUCTION IN THE BOX if it voided the warranty
  9. Crazykaktus
    Did you try what I suggested ?!
  10. 2kvfr800
    I will when i get home. Im on the road at the moment.
    I will also look up how to calibrate the ESC.
  11. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
  12. 2kvfr800
    What about the ground station?
Similar Threads - need upgrade advice Forum Date
Considering buying these upgrades, advice needed! General Discussion Jul 25, 2013
Need help upgrading P3A!!! The drone motors won't start after upgrade Pro/Adv Discussion Aug 12, 2017
P3 Firmware Any need to upgrade firmware on P3P? Firmware Jun 28, 2017
Much needed upgrade Phantom 4 Pro Discussion Apr 10, 2017
Is the FC40 P1 a "dead end" ? need suggestions upgrade or replacement path General Discussion Mar 20, 2017
