- Joined
- Dec 12, 2016
- Messages
- 5
- Reaction score
- 0
- Age
- 37
just crashe and broke fumble plate, not a big deal but antenna wires are pulled out. Idk how to solder any ideas. I live in Indiana
They are coaxial cables, so you won't be able to solder them. Unless you know how to rebuild them, you'll have to replace them.not a big deal but antenna wires are pulled out. Idk how to solder any ideas.
Mike, I think he is referring to the gimbal wires...They are coaxial cables, so you won't be able to solder them. Unless you know how to rebuild them, you'll have to replace them.
Thanks for all the input. Will take photo when I get home. I know it's not the ribbon wireAh. In that case, perhaps a photo would help.
Has it broken the connectors of the end of the coax? If they have just pulled of the sockets you can remove the two little plates on the gimbal housing and pop them back on. If the little plugs are broken your out of luck. The coax wires are permanently attached to 2 patch antenna one one either side of the battery housing in the Phantom 3 body shell.
Sent from my SM-G900I using PhantomPilots mobile app
Thanks a lot. Just ordered everythingYes, those are the coaxial cables from the antenna. You can buy a replacement here on Amazon.
