Need help upgrading P3A!!! The drone motors won't start after upgrade
I've been running the upgrade through the second card and it's been beeping and chirping for an hour now; with the little red light on the remote flahinf
How long should this take? Is there something I could have done wrong? I formatted the SD card, put the .Bi file on it and popped it in the slot, an hour later and it's still talking to me like rd2.
Edit:. The entire thing claims to have gone through only now the drone motors won't start
I tried auto take off and it says take off failed.
If I pull both sticks in and down nothing happens
Is the controller on a compatible revision level? re-link? What does the txt file say about the process?
I'm unsure how to pull a text file with it.
I've had it a year or so now, but haven't been in the air since November.
I'm going to try and relink it tomorrow morning and see what happens.
Was curious to see if this was a known issue. I did update the quad, camera and rc at the same time since they were all saying it was required.
I probably should have let it be, since I use litchi.
The text file will be on the sd card in the camera.
The txt file keeps repeating saying to abort because the card is identical to an older firmware on the craft.
I also tried relinking the rc but it still does not work
argues
