Ok, I have never had a totally successful flight yet. Bought in July, last year. Phantom 2 NV flies like it should.
The problem is that the Go Pro crashes when I fly. I get a "corrupted file" message.
Sometimes I get a minute of recording while flying, but usually not.
This is what I have observed and tried:
Go Pro 3+/firmware updated.
2) Samsung 64GB Evo 10 class SD cards, Checked to make sure Genuine.
SD cards formatted on Go Pro.
Using settings on Go Pro= 1080 30fps m view with camera every 5 seconds.
Camera works fine unplugged from the Phantom.
Camera works fine plugged into the powered off Phantom.
Camera works fine plugged into the powered on Phantom on work bench. (All 45 minute test).
iOSD works fine on the monitor overlaid over the video like it should.
What happens, when I fly, the camera turns off shortly and usually records nothing.
Sometimes it will record a minute, then I get an icon showing a bicycle on a page, which means a corrupted file.
Sometimes the camera shuts off and will not turn on until I pull the battery, reinstall it and plug it in to a charger.
I have pulled off the top cover of the Phantom and made sure that all the plugins are secure.
I need some help figuring out what is wrong.
Thanks!
Thanks!
