NEED HELP ENGAGEMENT PROPOSAL
Discussion in 'Phantom 2 Discussion' started by Hazendd, Nov 1, 2014.
  1. Hazendd
    My gopro 4 silver will not record when the ribbon usb is connected from the h3-3d gimbal. It records 1 second then freezes.... Help please guys. I'm pretty dejected that my newest upgrade has left me screwed. I sold the old go pro:(
    I have heard maybe something in settings? Can I connect go pro directly into a 5.8 video tx? That would mans life so much easier
  2. Damon
    Eastern Wa.
    What class rating is the memory card? GoPro's hate low budget cards. It should be a Class 10. Look at card and you should see a "C" wrapped around a number.
  3. Hazendd
    Samsung 64 evo. UHS 1 Class 10
  4. Hazendd
    Is there something in the settings on the go pro I'm missing?
  5. Damon
    Eastern Wa.
    I don't have a 4 so I'm of no help there. Would something like http://www.ebay.com/itm/like/201186000005?lpid=82
    work?
    You also might do the mod on the ribbon cable so only video is being pushed and no power charging etc are passing through ribbon.
  6. smallman28
    Referring to this
    viewtopic.php?f=26&t=19936
    Tricky to do but might be worth a go.
    I used a piece of sticky tape on mine.
  7. Noël
    Noël Guest
    re: NEED HELP ENGAGEMENT PROPOSAL
    Don't do it :)
  8. paulajayne
    Bocking - England
    Re format the card as well. May help.
Similar Threads - NEED HELP ENGAGEMENT Forum Date
Adding sound to my videos...need help Off Topic Today at 9:12 AM
Just starting need help Phantom SE Jan 11, 2018
Need help with Phantom 3 Standard Standard Jan 8, 2018
Need help with Pano Mode Phantom 4 Pro Help Jan 3, 2018
Flight distance maxed at 500 meters. Need help. Phantom SE Dec 30, 2017
