P3 Firmware Need expert help on Firmware Update
Discussion in 'Firmware' started by JeffH1970, Dec 24, 2015.
  1. JeffH1970
    Have a DJI Phantom 3 Pro. Trying to upgrade firmware. When I put bin file on card and insert in, red and green light flash for a minute or so with a low DDDDDDDDDD, then goes solid red with a solid beep. This is what the log looks like. I have tried several times. Please help!!
    ========== 2015.11.23 19:10:36 =====================
    Packet: P3X_FW_V01.03.0020.bin
    ========== 2015.11.23 19:12:20 =====================
    ========== 2015.11.23 19:15:09 =====================
    Upgrading ...
    Result: Corrupted.
    Firmware bin file is corrupted, download it again from the DJI offical website.
    ========== 2015.11.23 19:18:49 =====================
    ========== 2014.01.01 00:00:13 remo-con disconnect======
    Packet: P3X_FW_V01.03.0020.bin, P3X_FW_V01.05.0030.bin
    Result: Forbidden.
    Multiple version firmware bin files are detected. Please delete the redundant bin file.
    ========== 2014.01.01 00:00:14 remo-con disconnect======
    Packet: P3X_FW_V01.05.0030.bin
    Upgrading ...
    Result: Failed.
    Reboot the aircraft and try to upgrade the firmware again.
    Result: Failed.
    Upgrading ...
    Result: Failed.
    Packet: P3X_FW_V01.06.0040.bin
    Upgrading ...
    Result: Failed.
    Result: Failed.
    Packet: P3X_FW_V01.04.0010.bin
    Result: Failed.
    ========== 2014.01.01 00:14:02 remo-con disconnect======
    Result: Failed.
    Result: Failed.
    Result: Failed.
  2. barefootbeachcombing
    US
    Did you redownload the firmware file as the text file suggested?
  3. JeffH1970
    Yes I have several times. Does the same thing everytime
  4. TrynFlyn
    From the look of your log file, you never successfully installed 1.3.2. Reformat your SD card to FAT32, download 1.3.2 again, make sure the file is unzipped and only the .bin file is on the root directory of your card (not in a folder). Try again.
Similar Threads - Need expert help Forum Date
Phantom 4 pro experts in drone I need help Phantom 4 Pro Help Apr 5, 2017
Newbie help - Need your expertise/advice Phantom 2 Vision + Discussion Sep 26, 2016
Hey Expert's, ID needed.. Phantom 2 Vision + Discussion Aug 10, 2017
Needing expert advice General Discussion Feb 2, 2017
Need some expert advice on antenna rig General Discussion Oct 24, 2016
