Need advice.. Re: video, vs. trees between me and copter
Discussion in 'Phantom 2 Vision + Discussion' started by obiwan_pierogi, Nov 16, 2014.
  1. obiwan_pierogi
    It seems most posts that refer to upgrading one's copter etc., revolve around distance.. Bigger antenna, amplifiers etc. .. Whatever it takes to be able to fly further away.. This seems to be the ultimate goal for most copter pilots. Personally, I'm not really that interested in being able to fly 3 miles down the highway.. With my 2+ (line of site), I've been able to go 4,200 feet away, before the RTH feature takes over.. I'm quite impressed. However, when I went to check out something at ground level, just 200 feet away.. As soon as I got a couple of trees between me and my copter, I lost the transmitter signal and video feed.. What I want to be able to do, is fly over the tree tops on my property (within a 1,000 feet), and then in the clearings, drop down to ground level to check things out.. I know the wifi signal is severely affected by any obsticals -- even if you amp. it up.. Is there anything on the market, that would increase the transmitter and video links, when it's not line of sight? I know some radio frequencies work better in this respect, than others.. Thanks
  2. 4wd
    4wd
    North York Moors
    Re: Need advice.. Re: video, vs. trees between me and copte
    You can get aftermarket antennas but the way they increase the signal is focusing it more into a beam so not always ideal for everyday flying.
    A chainsaw maybe a better answer. :)
    Incidentally I expect leafless trees break up the signal considerably less?
  3. obiwan_pierogi
    I own a campground, and have my own wifi system.. I have a wifi booster, and it does help, pushing the signal through the trees, and the RV walls.. I'm wondering if the Lightbridge system would help, in this situation..
Similar Threads - Need advice video Forum Date
Need video setting advice....not a seasoned camera/video kind of guy Pro/Adv Discussion Oct 25, 2016
Rubbish Video Need Advice Phantom 4 Help Oct 1, 2016
Video playback probs, I think advice is needed, Phantom 4 Help Aug 23, 2016
Need some advice with friends drone anad video footage General Discussion Feb 29, 2016
Need Help And Advice on Video Photos and Video Feb 6, 2016
