Neck / transmitter straps .... And do I need a "balancer"?
Discussion in 'General Discussion' started by freefall101, Jan 23, 2015.
  1. freefall101
    Any recommendations on a good comfortable neck strap (lanyard type strap) suitable for RC transmitters including the Phantom 2 transmitter? And will I need a balancer, as these seem to appear when doing a simple eBay search? Thanks.
  2. Hughie
    Leeds, United Kingdom
    Re: Neck / transmitter straps .... And do I need a "balancer
    It is a matter of personal taste. I suggest you start with something cheap until you decide what you think you need. You should not need to move the COG using a balancer with a stock R/C Tx unless you have FPV kit mounted on it, and even then it is difficult to get it spot on.
    I was a little surprised that there wasn't a cheapo lanyard supplied with the kit, and so for my first few flights I used some thin nylon rope - it was absolutely fine. One problem I found with trying to buy a lanyard is that there are all too short (for me at least). So before you buy work out what length you might need, and check before you buy. Adjustable ones might be good.
  3. PhantomFanatic
    USA, GA
    You can easily make one. Wander through Wally World's craft section and you will find what you need.
  4. Hughie
    Yeah, I made mine in the end. very comfortable, and I didn't have to pay a tenner to advertise DJI ! :D
  5. Fplvert
    Southern Idaho USA
    :D
    http://www.ebay.com/bhp/transmitter-neck-strap
    I like the security of having a lanyard on my transmitters. Find one you like that is adjustable so you can keep the transmitter at a comfortable natural position. I use an iPad mini for FPV so I shift the center of gravity away from the bottom of the transmitter to keep everything upright.
    The other nice feature with a neck strap is you won't risk dropping the remote if you hand catch your bird.
  6. freefall101
    Thanks for the replies..... So I will have a similar setup but with a Nexus rather than iPad mini, how did you shift the centre of gravity to keep everything upright?
  7. Fplvert
    Southern Idaho USA
  8. mendezl
    Mandeville (New Orleans) Louisiana, USA
  9. johnp44
    Here is the one I found that I like: http://www.ebay.com/itm/Aluminum-Alloy-balanced-Hanger-RC-Transmitter-Neck-Strap-lanyard-Balancer-Blue-/271566396705?pt=LH_DefaultDomain_15&hash=item3f3a9e5d21
    I haven't found one that I like for my P3P. Hopefully someone has and will post the info here.
Similar Threads - Neck transmitter straps Forum Date
Best transmitter/tablet/neck strap held device Phantom 2 Vision Discussion Feb 2, 2014
Neck Strap Failure General Discussion Sep 3, 2016
DJI Neck Strap Issue Pro/Adv Discussion Aug 7, 2016
Neck Strap?? Pro/Adv Discussion Jul 24, 2016
Neck/back pain while flying Pro/Adv Discussion May 10, 2016
