Neat new App
Discussion in 'Pro/Adv Discussion' started by kphantom, Nov 10, 2015.
  1. kphantom
    Check out this aerial photo auto flight application. This is really neat.
    news & updates
    Bryan Joyce likes this.
  2. bKanzi
    Looks nice. Too bad I had to read through almost all of the story to find out its IOS only.
  3. bachstaber
    I just purchased nervous myself my question is how do I calibrate the aircraft
  4. bachstaber
    Lol airnest
  5. kphantom
    Just use DJI GO to calibrate, before starting Airnest.
  6. kphantom
    I bought it also. I finally had to upgrade to iOS 9.1 to get it. I hope I'm not sorry about that!
  7. bachstaber
  8. Darmie
    Houston TX.
    Please report back. IDK, end of the day here didn't understand fully what it can do.
  9. chrisnewton21
    Does anyone know how far out you can draw a path from your starting point with the Airnest app? Can it travel outside the RC range and if so will it continue on its intended path and return home as scheduled?
  10. III% Streve
    Considering the limitation to distance is the battery, and not the transmitters range.. not likely!
  11. chrisnewton21
    What is the maximum speed with the app? I know the waypoints with the DJI GO app will only allow 11.2 mph.
  12. BigAl07
    BigAl07 Moderator
    Staff Member
    Western North Carolina
    The AirNest Ap will fly beyond controller range simply because it uploads the flight to the aircraft itself. In reality (I've not tried nor would I do this) you can turn your Tx off once the Airnest mission has been launched and the aircraft is under way.
    In regards to how far I will ask Justin with AirNest to come here and give the details.
  13. III% Streve
    This is the case with most all 3rd party P3 apps.
  14. Justin Miller
    Yes Airnest will continue the path when radio contact is lost, its the main reason we force the Return to Home at the end of a path. This is more to do with the firmware setup than anything specific we are doing.
    The max speed of Airnest is 32 mph, though I don't recommend using that speed unless you are quite a ways over any obstacles and are using mostly a straight line, remember the quad does take time to stop at the end of a path. Safe Flying!
Similar Threads - Neat App Forum Date
A neat meters to Feet Conversion table Phantom SE Dec 25, 2017
Yikes! Hairline Crack Beneath Motor P3A. Out Of Warranty. General Discussion Oct 29, 2017
Neat little box for the P4 Pro Plus Phantom 4 Pro Discussion Jul 17, 2017
What is the coolest/neatest mod you've seen/bought/or heard of? Pro/Adv Discussion Aug 20, 2016
tape underneath gimbal Pro/Adv Discussion Jun 15, 2016
