NDJ6 V2 doesn't respond to S1 switching to calibrate
If this is a P2 non vision quad and you have no camera attached how in the world do you expect to see a satellite count on an app. Look to be perfectly honest with you you really need to read the user's manual a few time because you simply do not have a clue as to how this equipment works.
Still waiting for you answer? I read the manual and followed the instructions. THE LIGHT DOESN'T TURN YELLOW ON THE REMOTE. So how does your smug response help? Thanks man have truly helped me...
Check your personal messages.
Plug your P2 up to the software and go into the basic tab with RC turned on and under RC see if S1 (U slider) is even working.
@rudycoop you should look into this comment by @Jason.
The 3 position S1 and S2 switches by DJI are NOT reliable. They have a high failure rate. Luckily they can be replaced for 2 dollars at your local radio shack.
If you plug your phantom into a MAC or PC goto to BASIC > RC, you should see how the remote behaves. If you flick your S1 and S2, you will see the sliders change values.
Spicehub
