ND Filter... why should I get one?
A ND filter is simply a way of reducing the light coming through your lens in brightly lit situations - sunglasses for your camera.
Tricky to use on a Phantom because it makes the camera/gimbal unbalanced.
Better to concentrate on shooting away from the sun rather than towards it.
Naw, you can get great shots not only against the sun, but nd filters also make reflective things nicer, ie. water, glass structures etc.
The gimbal works fine with filters/protectors. You can add a counterweight the same weight as the filter on the opposite arm if you like.
jrl
