Naza wiring
Hello need to get photos of the controller/naza I'm replacing my center board I took photos but not good Ones so can someone send me the pictures I have all but one in question I have looked everywhere thanks again
Hello,
Here is the correct ( Stock ) P2V NAZA-M wiring.
Picture 1:
The Camera Servo wire connects ( Vertically ) up-down on ( F2 slot on NAZA-m box )
( see pic 1 above for correct color placement )
The wire next to M2 plug on MC ( main controller ) plugs ( Horizontally )
Side-side ( bottom most pins ) across ( M1/M2/M3/M4 ) pins!
Ok,
Picture 2
USB Com port wire, ( plugs Horizontally ) top most pins, across
( A, E, T, R. Pins )
( see pic 2 for correct color placement )
Picture 3:
This wire hooks ( horizontally ) across ( U, X1, X2, X3 ) pins ( top most pins
( see pic 3 for placement )
Picture 4:
Wire #1 hooks ( vertically ) on X1 slot ( goes under pic 3 wire )
Wire #2 hook ( vertically ) on X2 slot
( also goes under pic 3 wire )
Wire #3 hooks ( Vertically ) on X3 slot
( goes under pic 3 Wire )
Hope this helps!
Take Care, Fly Safe!
J Dot
Reactions: dirkclod
I thank you but I have the vision 2 I took photos before taking it apart mine did not look like the photo your showing thanks for helping
Pic 3 look's different then mine I wish I knew how to add my photo on here to show you I guess I'm stupid
