Naza V-1 to Naza V-2 conversion
Discussion in 'General Discussion' started by Audaciter, May 31, 2013.
  1. Audaciter
    Sunnyvale, California, USA
    Well, I actually completed it about a week ago, but my depression and anxiety were so bad that I didn't connect it to
    the Naza Assistant and update it until this evening.
    It was a complete success. I began by getting rid of the main board and the led module. I then mounted a power distribution
    board underneath the carbon fiber plate I made to replace the main board.
    Up top, I put the Naza V-1 controller in the center, as it should be. Then I mounted the PMU-2 next to the Naza, and my
    Futaba receiver on the other side.
    I mounted the V-Sense / led module outside, attached to the legs for my gimbal, so I can see the flashing led, and I can
    plug my cable directly into it when connecting to the Naza Assistant.
    Everything went as well as could be hoped for, and the Phantom flew great.
    For those of you not familiar with my machine, I am running T-Motor 2214-11 Anti Gravity motors, 9" carbon fiber props,
    Phantomount X2-wide gimbal and GoPro with waterproof housing. (Heavy!)
    I'm not sure if there is really a difference between the Naza Assistant software for the Phantom or not, but I am definitely
    NOT using the Phantom version.
    If anyone is interested in Pictures, I will probably post some when I get a better grip on my anxiety and depression.
    So stay tuned.
  2. Gizmo3000
    Sherman Oaks, CA
    It's all the same software now.
    in their latest release, DJI put everything under one roof so to speak. everyone is on software 2.12 and firmware 3.12
Similar Threads - Naza Naza conversion Forum Date
Nazareth, Pa Airspace Wow Rules and Regulations Sunday at 3:08 PM
Repair DJI Phantom 2 Vision NAZA Phantom 2 Help Jul 16, 2017
naza assistant with android Phantom FC40 Discussion May 1, 2017
Naza won't recognise my pv2+? Phantom 2 Vision + Help Apr 8, 2017
Problem with GPS, NAZA upgrade Phantom FC40 Discussion Mar 24, 2017
