Hey Folks
I have the phantom setup in Naza mode with S2 position 1 off, 2 course and 3 home.. which is the default (can't change this anyways can you??)
I've tested the controller can goto each setting when I click S2 when the phantom is connected to the PC via assistant software. IOC is enabled to.
Course lock works and is pretty cool / useful..
RTH mode works when I set it via S1 (S1 position 3 is set to fail back or what ever that setting is... but NOT manual or ATTI)
Problem is.........Home mode however doesn't seem to work.. Its my understanding when you press/hold?? down on the right stick in will fly back to the home position
when you are in GPS mode and have 6+ satellites (and home is set).. It should hover home at 20feet for 15 seconds than land yeah ???
Also I've read it will only do it if the phantom is 30+ feet away..
anyways when I have 6+ sats in GPS and click S2 to Home.. I press/hold down on the right stick.. in just flys backwards, similar to course lock.. it definitely doesn't fly back to the home position... It doesn't care about home.. It will fly backwards until you take your hand off down....
When I switch to 'home' it will flash yellow every now and again which I assume indicates its doing something special..
Am I doing something wrong ?
I believe the phantom is in Naza mode (as set via the assistant PC software) because course lock works and RTH works, and when it was in Phantom mode, S2 did nothing as expected.
