NAZA - Home Lock
Discussion in 'FPV (First Person View)' started by NoRush, Mar 8, 2015.
  1. NoRush
    Auckland, New Zealand
    Quick question. Is it feasible, when flying in NAZA mode (assumed out of sight), to fly (up) to an altitude well above any perceived obstacles (trees, steeples etc) prior to activating the S2 Home Lock. What S1 switch position would be required for increasing the altitude? Cheers - NoRush :)
  2. Monte55
    Raymore Missouri
    I may not totally understand your question. S1 has nothing to do with how high you fly..that is done with throttle. Next..if you can't see it, how would you know how high you are unless you have telemetry etc. You have not stated what you're flying.
  3. MrC
    MrC
    Surrey. UK
    Assuming you were flying in gps mode anyway (S1 in upper position), then yes, gaining some height to be sure of a clear path back would be prudent. Just left stick up first, for a few seconds, careful not to go crazy high. Then flick S2 to home lock and pull back on right stick and bobs your uncle.
  4. NoRush
    Thanks MrC; that's the answer I was after. Can I assume the S1 switch remains UP throughout this process?
  5. Hughie
    Leeds, United Kingdom
    Yes Home Lock requires GPS, Course Lock does not.
  6. Monte55
    Raymore Missouri
    I actually did a test this morning with my P1. As said above...HL needs GPS..CL does not. I flew out a ways in front of me and off to one side to be sure HL was working ok when I pulled back on right stick.. It was. When HL brings the quad back to starting point where you aquired CL and HL..when it gets to about 30 feet out, it goes to course lock. SO, if you fly it behind you in in CL, HL no longer will bring it back to home point. Solution....while craft is behind you, flip S2 to off and back to HL and it comes back to home point again with right stick down until it gets within the 30 feet area and goes back to course lock and reverses direction. . Actually fun to do.
  7. NoRush
    Great experiment Monte55. Does the result of your experiment suggest that HL mode does not auto land and "shut-down" the drone at its home point? I'm trying not to confuse S1 RTH & S2 HL modes!
  8. Monte55
    Raymore Missouri
    Home lock does not auto land. All it does is know where home point is..and if you are out and get confused as to where the quad is or the way it is facing...switching to home lock with S2 and pulling back on right stick will bring it back home. You must be in top position with S1 which is GPS mode.
  9. NoRush
    Thanks Monte55; very succinct. I now clearly understand the distinction between HL & RTH in NAZA.
  10. Monte55
    Raymore Missouri
    But in either HL or RTH, you must be sure at startup you have locked in CL and HL for it to work. Also be sure the quad is facing the direction you will remember for course lock to work as you would expect. Otherwise when returning in home lock mode and it switching to CL when it gets close, it may take off in another direction. Home lock is just to bring it back close enough for you to take control again.
  11. NoRush
    OK, I'll bear that in mind with my trials. Thanks again. After a windy Spring season (normal) in Auckland New Zealand we have just finished a relatively calm summer and so far also for the start of our autumn season. Winter is usually relative cool but calm; i.e. we have only rare weather extremes - so here's looking forward to lots more flying to try out out these new tricks. Currently 28.5 C (83.3 F) with 10 km/h winds.
Similar Threads - NAZA Home Lock Forum Date
IOC - Home Lock ... Naza.... so confused.. Phantom 2 Discussion Sep 28, 2014
Question on Home Lock in NAZA Mode Phantom 2 Vision + Discussion Aug 6, 2014
Naza M home lock question Phantom 2 Vision + Discussion Jul 28, 2014
NAZA Home Lock & Course - not working Phantom 2 Vision + Discussion Jun 27, 2014
Naza Home Lock saved me - Lost Control with near fly-away Phantom 2 Vision + Discussion May 31, 2014
