my phantom is flying bad since gimbal installation
Hi,
I've installed this gimbal:
http://www.ebay.com/itm/RTF-Gopro-H...Control_Parts_Accessories&hash=item3cde3cef4f
since then my phantom is not aligned.
1. liftoff is weird, it goes nose down all the way and then goes up.
2. when its on the air its always tilted to the right.
3. it doesn't maintain position and height, its hovering all over.
4. when i fly forward it doesn't maintain height and it going down slowly .
* gps is ok, all green.
* i did advanced calibration through naza software
* i did a campus calibration.
Any ideas what else should i do?
You want to have play with gain
to stop it tilting to the side you want to change the roll if your looking at the front when its in the air and its tilted right lower the basic gain roll by 10. I had to do this and it worked. now sounds like you need to calibrate your controller i would do this first make sure its all fine do you know how to do this? once thats done then see if your experience the same problem when flying forward and taking off. if so adjust your vertical basic gain.up by ten and see how that helps. When you have conected you phantom to pc with the assistant software it will say what each one does any way. hope this helps let me know how you get on and good luck
Hi,
I forgot to say that i calibrated the remote already.
I will try to play with gain.
How can i fix the nose down while take off?
jozee said:
Hi,
maybe the front propelers not going fast enough has it been like this since you got it ? if so call the supplier if not have a play with the gain have a look at a chart that explains yaw roll and so on you will be able to see what you will need to adjust form the picture
cokersean20
