My P3P controller will not stay on. HELP Plz
Discussion in 'Pro/Adv Discussion' started by johnp44, Sep 12, 2015.
  1. johnp44
    I have a new problem with my P3P controller. When I try to power it up now, the left most led does not ligtht at all and the other four light up for about three seconds and then go dead. The battery is charged and shut when I charged it. Nothing I have tried works.
    UPDATE:
    I went ahead and opened the controller and found the battery was swollen and apparently not able to provide enough current to keep the controller active.
    Thanks for the replies, After many flights, I know that it turns on with one push followed by a second just like the quad. But thanks for the suggestions!
    Now off to find a replacement battery.
    #1 johnp44, Sep 12, 2015
  2. RCPILOT
    Winnipeg, MB Canada
    Sounds like your not turning it on. Press the button once to check the battery level then press it and hold it for two seconds to turn the transmitter on...
    Oso and brianb87 like this.
  3. RedHotPoker
    Edmonton Alberta
    One press is how you/we check our intelligent flight battery level.
    Double press and hold for a couple seconds and the power up cycle initiates.
    Perhaps "RTFM" again, and then "RTFM" one more time... ;-)
    It works the same for the radio controller, single click to check power level. And a double click to power on.
    But of course you already knew this, from "RTFM"!! Hahaha
    Enjoy your explorations... And learning curve. Shaped like a rainbow.
    RedHotPoker
Similar Threads - P3P controller stay Forum Date
P3P controller Pro/Adv Discussion Tuesday at 3:46 PM
WTB: P3P Controller Shell Classifieds Aug 8, 2017
WTB: P3P controller Classifieds Aug 3, 2017
Can I update my P3P without using the app/controller? Pro/Adv Discussion May 23, 2017
Standard P3P controller and batteries compatible with P3S Phantom 3 Help May 17, 2017
