My gimble switch is not working
Discussion in 'Phantom 2 Discussion' started by enormeBRAGA, Sep 22, 2014.
  1. enormeBRAGA
    Greetings from Portugal
    I have a problem with the gimble switch in the remote.
    I can move the gimble in the RC software, but the switch in the remote, doesn't move the gimble.
    Any suggestions?
  2. HarryT
    Warrington, UK
    First run RC Assistant, and move all the controls - including the gimbal - through their full range of motion. Then run Phantom Assistant and do the same. When you move the lever, you should see channel "X1" moving in the Assistant software. Then, in Phantom Assistant, go to "Advanced", then "Gimbal", and set the range of motion of the gimbal.
  3. Crazykaktus
    You probably have the same issue I had. The actual lever on the control has a small star connector that pushes into the potentiometer mounted on the board. Mine was not connecting to the pod. Put a small screwdriver underneath the pod and gently raised it up. Put the cover on and voila - solved
  4. enormeBRAGA
    Thank you both... HARRY T, maybe I didn't explain myself, when I said that I can move the gimble in the RC software... I can move the gimble with the mouse, not with the switch... With the RC software the switch isn't move either.
    Crazykaktus, I believe that the problem is possible to be somewhere close to that. I will try it. Do I lose warranty if I open the remote?
  5. HarryT
    Warrington, UK
    Sorry for the misunderstanding. In that case, I agree, it sounds like a hardware problem in the Tx.
  6. enormeBRAGA
    It's ok, my English skills did not help... But thanks anyway.
  7. enormeBRAGA
    Thank you, thank you, thank you...
    I was nothing without you guys...
    Works like charm...
Similar Threads - gimble switch working Forum Date
Gimble Dead Phantom 4 Discussion Today at 3:07 AM
P4p gimble yaw motor overloaded Phantom 4 Pro Help Aug 6, 2017
Phantom 2v gimble wiring Phantom 2 Vision + Help Aug 5, 2017
Replacement Gimble Arm for P4P Phantom 4 Pro Help Jul 26, 2017
Professional P3P gimble motor Phantom 3 Help Jul 25, 2017
