My first flyaway !
Discussion in 'General Discussion' started by knuckles, Nov 30, 2014.
  1. knuckles
    Arizona
    wow, thankfully you had that tracker that no doubt paid off.
    Any clues as to what caused this to happen?
  2. Happyflyer
    Cold, Cold, Michigan
    +1 on questions.
  3. Happyflyer
    Makes one wonder when will it happen.........?????
    Maybe never.
    I don't have to worry about it. No fly weather here until Spring.
  4. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Did you recalibrate the compass after moving the tracker? Putting a ferromagnetic material near the compass is generally a bad idea. The TX/RX in the tracker can potentially cause issues for the compass as well.
    However, without video, this is just speculation.
  5. Prylar Bek
    Can't tell from your pic. What was wrong
  6. Prylar Bek
    Oh duh!!! My bad
  7. ianwood
    Staff Member
    Lost Angeles
    When the compass gets bad data, it's not often immediately noticeable. I don't know why. There are a bunch of fly aways where someone took off from a ferromagnetic surface like granite, all seemed fine for a number of minutes and then the telltale indications of compass induced TBE and loss of control ensue.
    I'd suggest you move the tracker to another location, recalibrate the compass and then check the mod value just to be safe.
  8. turbodronepilot
    Prather CA
    Hey there dirkclod. .I can't believe your bird flew the coup. .was going to mention getting a locator 8.. they're great.. I'll have mine on board with my tracker if I ever get it going. .haha..
  9. eyecon82
    I already has my tagg pet tracker recover my bird once already
  10. Idbird
    :eek:
    I've done that too!
    Glad you got your bird back Dirkclod!
    What could have happened to cause the erratic behavior?
  11. un hombre
    Ireland - Poland
    Wow, close one. Lucky!
    I don't have a tracker because where I fly, there is no GSM range anyway... :)
  12. Hughie
    Leeds, United Kingdom
    How did you do your "If Found" lettering ?
  13. un hombre
    Ireland - Poland
    Re: Odp: My first flyaway !
    Yes but how will you activate it if you can't send sms or call it? :D
  14. MadMitch88
    Cleveland, OH
    That is why I use a superior tracking device like the Flytrex Live --- it will automatically upload last known GPS position to the Flytrex data center in Israel --- then all you have to do is login to your Flytrex account on any Internet device and click the "Last Seen" page to find out where your downed bird is located (accurate to within +/- 10 meters).
    No need to "call in" to your tracker and worry about it whether it's in a good GSM reception area. :p
  15. richiewrt
    Doesn't it need a cellular data connection for it to upload to flytrex?
  16. IflyinWY
    Where the deer and the antelope play
    I have the same problem.
  17. ianwood
    Staff Member
    Lost Angeles
    Flytrex uses the same 2G/3G networks as Dirkclod's tracker does. Though the tracker may only be 2.5G which depending on where you live can make a big difference.
    The Flytrex has an advantage that it will post the data to the cloud whereas the tracker is point to point and must be still connected to return a position when requested. Either way, your Flytrex/tracker needs a connection with a mobile network at some point during or after the flyaway to be useful.
Similar Threads - flyaway Forum Date
P3P PHANTOM FLYAWAY I FOUND SOMETHING ASTONISHING IN THE LOG's General Discussion Jul 1, 2017
Get logs after Battery Overcurrent, Flyaway+Crash General Discussion Jun 27, 2017
Flyaway issues? Standard/4k Discussion Jun 7, 2017
Is a flyaway possible in atti mode? Phantom 2 Help May 1, 2017
Phantom 4 Pro Flyaway Phantom 4 Pro Discussion Apr 15, 2017
