Hi All,
I have read with interest the experiences of other Phantom 4 Pro owners and firmware V01.04.602 and thought I would give it a go myself. I use my aircraft with DJI GO 4 and Litchi. Here are my observations:
Upgrade:
Hope this information is of help to anyone that wants to try the new firmware.
Don Barar
Upgrade:
- Aircraft Firmware. Aircraft firmware was updated using DJI Assistant 2 V1.01-2 operating on a 2016 MBP15 using OS X 10.12.5. Firmware upgrade proceeded with no issues.
- R/C Firmware. Controller was connected to iPad Pro 9.7 operating under iOS 10.3.2. DJI Go 4 app was launched. There was a message that indicated R/C firmware needed to be updated. R/C firmware was updated using the iPad. No issues with the update.
- Batteries. All batteries needed to updated. This was done using DJI Assistant 2.
- IMU/Gimbal/Compass Calibration. After firmware updates my process is to calibrate the IMU, gimbal and compass. All calibrations proceeded normally.
- Turned aircraft/controller/iPad on. Aircraft went through it's boot-up.
- Confirmed all settings. Several have commented on Smart RTH no longer available to be turned off in the battery section. Before I performed any firmware updates I checked to see if the Smart RTH toggle was available. It was not. My impression is that app version 4.1.0 removed the Smart RTH toggle and not the firmware.
- First flight appeared normal. Sticks seemed more aggressive. I noticed no improvement with horizon tilt. However, I never had much of an issue with horizon tilt.
- Turn on Aircraft.
- Turn on controller, iPad and launch DJI Go.
- Allow aircraft to boot-up and find GPS satellites.
- Kill DJI Go app. This is done by double clicking the home key and 'swiping" up on the Go App to make it disappear.
- Lunch Litchi app.
- Launch aircraft.
- I was able to fly with the Litchi application FPV with no distance limitations.
- Flew several missions with Litchi Waypoint and Focus modes. These proceeded normally. Did not encounter any issues when flying waypoint missions terminating early because of Smart RTH activation. However, as a Realtor I never fly missions that far away from my launch point.
Don Barar
