My DJI phantom 3 professional lost control and crash
Discussion in 'Pro/Adv Discussion' started by Droneflyer06, May 30, 2016.
  1. Droneflyer06
    I'm new on here and not sure how everything works on here. I did everything as I always do before flying. I have a DJI phantom 3 professional. Was getting 14 satellites and showed that it was safe to fly. Took off and at about 78ft I heard a click and the and the motors sounded like they were revved all the way up. Drone tilted sideways and headed to the ground. I tried to to control it and nothing! It all happened in 12 seconds. From take off to crash
  2. Reed L
    Alta, Ca.
    Lost or broke a prop or motor...
    Oso likes this.
  3. mikesmiley
    Sacramento, CA
    Sounds like you lost or broke a prop.
  4. Dounin Front
    Castle Rock, Colorado
    Where did you find the missing prop?
    Sorry for your loss.
  5. Ghost Rider
    Lost prop sends the aircraft tumbling.
  6. Othan1
    He should post the logs. It's not unheard of that the craft simply fails. I had one do that and DJI had to repair it after reviewing the logs and such.
    You can skip to close to the end, but this is what a death from software/firmware failure looks like.
    Reed L and Digdat0 like this.
  7. Droneflyer06
    Thanks for the response. props were all there, one broke on impact. It went down really fast! Here is a copy of my flight record
  8. Meta4
    Meta4 Moderator
    Staff Member
    The flight record shows multiple Speed Error warnings indicating a problem in the propulsion system.
    Upload your flight record to DJI (click the cloud icon in the app)
    Contact DJI online support: DJI Support - Phantom 3 Professional
    And they should take care of you.
  9. Droneflyer06
    Could you figure out what went wrong?
  10. Meta4
    Meta4 Moderator
    Staff Member
    Maybe an ESC malfunction ?
    Whatever it was your Phantom was in trouble and nothing you could have done would have fixed it.
  11. Droneflyer06
    Yeah it seem like it went rogue and head straight for the ground. What is normally the cause for that?
  12. MarcMcfly
    Everytime I fly mine I take off and kind of wait for some seconds hovering low, just in case there is a broken prop, I can see it before going higher or if it crashes, it won't be that bad.
    Do you know if there is something like a minimum period of time for testing props hovering, so it would be safe to fly after that? Does anyone else have another way to prevent that from happening, except checking the props before flying?
  13. UKFlyer
    Midlands, UK
    After i hand tighten them i give them about a quarter of a turn with the prop wrench to make sure they're tight.
  14. Meta4
    Meta4 Moderator
    Staff Member
    If you don't crash them and don't over-tighten them, your props will last a long time.
    They only need to be finger firm.
    Tightening a quarter turn sounds too much and you should not be using a wrench.
    The wrench is for loosening too-tight props after a crash.
  15. Droneflyer06
    The prop broke on impact and was next to where the craft crash.
  16. GenesisX
    Reading, MA
    Good info here! Thanks.
  17. Dounin Front
    Now I'm really curious. Keep us posted what you learn from the logs and DJI.
  18. Darmie
    Houston TX.
    BTW, what is the warranty of the Phantom?
  19. Droneflyer06
    Okay. Think the warranty is one year
  20. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It depends on which part you're referring to. You can find the warranty time periods by part on DJI's website here.
    Darmie likes this.
Similar Threads - DJI phantom professional Forum Date
Dji Phantom 3 professional Bundle !! Classifieds Dec 23, 2017
DJI Phantom 3 Professional Classifieds Dec 11, 2017
SOLD -DJI Phantom 3 Professional - lots of extras - FREE SHIPPING CONUS Classifieds Dec 4, 2017
DJI Phantom 3 Professional and extras Classifieds Nov 29, 2017
DJI Phantom 3 Professional 4k Classifieds Oct 15, 2017
