My board sparked on first power up.
Discussion in 'FPV (First Person View)' started by cikmatt, Feb 17, 2015.
  1. cikmatt
    http://i.imgur.com/Kzglp2t.jpg
    This was a plug n play cable. No soldering. I got build feedback from three different forums before purchase and installation. In fact, everything came from the gear thread here.
    What are my options here?
  2. Geroghost
    I had the same issue. If you got a plug n play cable for the fat shark n immersion transmitter but you weren't using such that would happen. Took my phantom 2 to a certified repair shop. Should have an exact answer n cost within a few days
  3. cikmatt
    This was the equipment list I used:
    viewtopic.php?f=31&t=33366
    So far the help I've been getting from a few other sites I've posted on has suggested it was a bad component on the board itself, and that I'm looking at a $59 dollar replacement on the part, plus whatever for labor. I've spoken to Dronefly http://www.dronefly.com/category-s/1820.htm and they seem reasonable, but I'm going to inquire locally if the tech guy at work could give it a try, too.
  4. Reoscorpio
    Lisle, IL
    I used that cable with a Boscam 353 as well with no problems like what you've experienced. I did double check the cable orientation before powering it up just in case as their seems to be so many rebrands with minor differences that I didn't want to risk anything.
  5. shooter60
    Texas
    Mine did the same thing when I tried to put a L-C filter in, mine will start up just scared to fly it until
    I get a new board going to try to do it myself because in small town TEXAS there is nobody to work on them
  6. jason
    Commerce Twp,MI
    Well I know you shorted out cameras power supply. But what I don't understand is where you were connecting it to and how you shorted it out.
  7. cikmatt
    So I spoke with the pnp cable's seller. Indeed the wires were wrong on my plug and play cable and the seller is moving to replace both the cable and my phantom's center board.
  8. dptcalvin
    Good customer service admits when they're in the wrong and do right by correcting their mistakes. What seller?
  9. cikmatt
    DPCAV.com
Similar Threads - board sparked power Forum Date
Professional P3A and P3P main board Phantom 3 Help Thursday at 7:30 PM
Phantom 4 Video Processing Board with Fan. Phantom 4 Help Aug 12, 2017
Professional How to initiate the "Aircraft Initiation" after replacing pn #96 ESC board Phantom 3 Help Aug 4, 2017
Standard Is this a pitch motor or board issue? Phantom 3 Help Aug 2, 2017
P3P Gimbal circuit board wanted Pro/Adv Discussion Aug 2, 2017
