MOV or MPEG ?
Discussion in 'Pro/Adv Discussion' started by Hugh-1, Oct 12, 2015.
  1. Hugh-1
    Syracuse, NY
    Have been recording in MOV format and it seems to be fine. Just wondering if there is a prefernece between the MOV and MPEG formats? Is one better then the other ? Also what is the 2.7K resolution available on the P3A equilvalant to, and is it better then 1080 ? Thanks guys.
  2. Meta4
    Meta4 Moderator
    Staff Member
    Should be no difference. The formats are essentially the same but inside a different package.
    2.7K is higher resolution (more pixels) so it can show higher detail but that requires bigger file sizes.
    • 2.7K: 2704 x1520p 24/25/30 (29.97)
    • FHD: 1920x1080p 24/25/30/48/50/60
    Neither is "better". Which to use depends on what you are shooting for and what your requirements are.
  3. B- Scene Films
    MP4 and MOV are just wrappers. If you use Mac, use MOV. Windows, use MP4.
    The 2.7K equivalence - not sure what you mean there. If you scale the 2.7K footage down to 1080, it will look better than 1080. A 2.7K frame also allows you to re-frame your shot after the fact since it's bigger than HD.
    clkilljoy likes this.
Similar Threads - MOV MPEG Forum Date
Mpeg or Mov Phantom 4 Help Nov 18, 2016
MOVERIO BT-300 v. BT-350? MOVERIO FPV Smart Glasses Monday at 6:41 PM
Phantom 3 vibration after removing motors Pro/Adv Discussion Thursday at 1:19 PM
P4P+ w/ Moverio BT-300 Drone Edition Phantom 4 Pro Discussion Jan 9, 2018
Payback can be a ( MOD REMOVED ) Off Topic Jan 8, 2018
