Motors won't turn on, get fast blinking green LEDs w/ CSC
Discussion in 'Phantom 2 Discussion' started by adster, May 29, 2014.
  1. adster
    So I finally got everything updated and calibrated on my P2. I disconnect it and test out the the startup in my living room. I move the throttle to the CSC position and everything starts up in my living room. Booya.
    I head outside and wait for the all-green blinking lights showing I have satellite lock. I try to turn on the motors but they won't turn on. Each time I try using the CSC throttle command, I get a series of very fast blinking green lights.
    Is it something to do with the GPS? I'm not in a no fly zone (but theres one about 8 miles away) however you can at least startup the motors in a no-fly zone, right?
  2. Sanababit
    Re: Motors won't turn on, get fast blinking green LEDs w/ CS
    Did you calibrate the remote control too?
    Sana
  3. ginsonic
    Need calibrate remote control. This happen to me too and fixed after calibration.
  4. adster
    Yep, remote is calibrated. I'll run the calibration and then turn on the motors inside and they work just fine. But if I turn off the copter, take it outside and try again I get the flashing green lights. I shouldn't have to calibrate the remote each time I turn on the Phantom?
Similar Threads - Motors won't turn Forum Date
3 of 4 Motors won't turn up to speed Phantom 2 Vision + Discussion Jul 3, 2016
Motors won't turn, but Assistant says calibration not needed Phantom 1 Help Jul 11, 2015
Need help upgrading P3A!!! The drone motors won't start after upgrade Pro/Adv Discussion Aug 12, 2017
Phantom 4 motors won't fully start Phantom 4 Help Jul 20, 2017
motors won't arm and no leds after i replaced the shell. Phantom 4 Help Jul 4, 2017
