Motors Start the opposite of the instruction manual
Discussion in 'Phantom 2 Vision + Discussion' started by davidsoncm, May 20, 2014.
  1. davidsoncm
    Just recently I tried to fly my phantom 2 vision plus I was unable to get the motors started after recalibrating the tx now the motors start with the CSC the opposite direction up into the outer corners instead of down to the inner corners of the TX opposite of what the operators manual says. Any idea on how to fix this? thanks
  2. Mori55
    NJ-USA
    Works either way look at manual
  3. davidsoncm
    Maybe I should have been more clear. It will NOT start with sticks down and into the lower corners and inward,will ONLY start with sticks up and outward.
  4. MikesTooLz
    Miami, Florida
    Sounds like they are inverted.
    Did you by any chance connect it to the computer via USB and change anything with the software?
  5. AnselA
    Declination +8° 11'
    Did you use Vision Assistant or RC Assistant to do the calibration?
  6. davidsoncm
    Both actually.
  7. Mori55
    NJ-USA
    Ok sorry about that. Guess you'll have to turn the radio upside down ! :D but will it take off ? Does everything work right then ? Do your motors turn in the right direction ?
  8. Mori55
    NJ-USA
  9. davidsoncm
    Thanks Mori55. Yes it flys fine. I'll check that when I get home thanks for the pic.
Similar Threads - Motors Start opposite Forum Date
Three Quick Green Flashes When Trying To Start Motors Phantom 1 Help Wednesday at 1:32 PM
Need help upgrading P3A!!! The drone motors won't start after upgrade Pro/Adv Discussion Aug 12, 2017
Standard Newbie needs help starting motors Phantom 3 Help Jul 28, 2017
Can not start motors with left stick full forward p4p+ & RTH takes forever to land Phantom 4 Pro Help Jul 25, 2017
Phantom 4 motors won't fully start Phantom 4 Help Jul 20, 2017
