Motors quit at 10%
I flew today down to 22% and landed at the home spot. It is time to drain down to 8% so I took off the blades and let it run down. At 10% the motors quit!!! Is this normal that motors will quit at 10% (and fall out of the air) or was it because I was at the home position so they quit? I normally land at 20-25%.
After you removed the props, did you start up the motors using auto take off? If so, it's normal for the motors to stop after a few seconds if the props are removed and the P3 does not ascend.
No. I started it manually. I let it run down to 10% at the the home position. Then at 10% the motors quit. So, I took the props off (started it again manually) and let it run down to 8%.
Normal i believe. 10% is critical, so it will land itself. If already landed, why not shut off?
Reactions: Oso
Gotcha. So what levels do you have your low and critical battery warnings set for? It must have reached your settings.
Sorry, didn't see your post. I should have refreshed but I'm deep into the Mets/Dodgers game.
Reactions: PilotHarry
Same thing for me. Couldn't run it down to 8 percent because the motors won't run below 10.
I didn't know this!
So, you're telling me that my Phantom will just fall out of the sky if the battery gets to 10 percent?
This can't be!
I didn't know this!
This can't be!
No, but it will immediately try to land. If it's already landed (as in this case), it will cut off the engines.
Pauos31
