Hi, I have just bought a Phantom 3 Standard, updated to latest firmware and use it with Motorola Moto G 2nd gen running Android 6. I notice quite a lag between camera and screen meaning depending on camera view on mobile is a no go, did you experience this? Video is perfect BTW.
I also find more often than not that after starting aircraft, controller, connecting WiFi then running Go App that it doesn't show the correct model and blue (active) camera button but the How to Connect button i.e. it hasn't connected, have you had this?
PS - I've been flying it a few days, learning a lot, reading manual, forums etc. It has successfully returned to home using the app or flipping the S2 switch a few times. Today, I though I would be bold and sent it off at a few metres up and at some speed until it showed weak signal, I then toggled the S12 switch, it said returning to home but I couldn't see it. Eventually it was showing out of range and maximum engine speed reached! I found it 15 minutes later in a tree at head height with 2 broken props, with 2 blades still spinning. Though I felt lucky I am unsure why it didn't return, and for once I didn't have video recording. Although it was showing within range when I got near it I couldn't work out how to get it to show me where it was, the map view was greyed out! Any advice, other than don't be stupid, would be appreciated ;-)
