Motor screw stripped (help)
Discussion in 'Pro/Adv Discussion' started by AdamDomenico, Jun 5, 2016.
  1. AdamDomenico
    This morning, I installed prop guards with the correct screw and the screw that mounts in the motor became stripped. Not sure how this happened, I was barely tightening it and of course it was the last one. Long story short I decided I didn't really need prop guards and took them off, but now I have a motor with only 3 screws. Does anyone have any recommendations on what I should do. Can you fly with only 3 screws temporarily. I'm currently in Kazakhstan and will be back to the states in 2 weeks so I can't really get any parts here. I've attached pics. [​IMG][​IMG]
  2. tcope
    Salt Lake City, UT
    Personally... my opinion, you should be fine. I'd not fly it forever light that but I'd say several flights you'd be fine. You may want to try to avoid full throttle.
  3. Sinisalo
    so the threads on the screw are stripped but the threads inside the motor are not stripped right? I wouldn't fly with one screw missing but that is pretty much the same as people who have a cracked shell and still fly.
  4. AdamDomenico
    It's the threads on the motor.
  5. Sinisalo
    I would go easy on the throttle and just as important would be to turn down the air brake settings. Under Advanced Settings> Sensitivity>Brake, change it to something like 60% to put less stress on the motors and arms when you stop.
  6. AdamDomenico
    Thanks, Sinisalo. Is it fairly easy to replace the motor myself once I get back to the states?
  7. Sinisalo
    yeah, they are $18 or so on the DJI website, you could order it now so it will be there waiting for you when you get back. When you solder the wires just make sure you pre-tin the wires and don't use lead free solder as it could crack and cause a mid flight failure.
  8. Sinisalo
  9. AdamDomenico
    Thanks a lot, I'll order it right now. I appreciate your help.
  10. Sinisalo
    no problem, welcome to the forum.
  11. SnoozeDoggyDog
    And take the God ugly prop guards off... Apart from them being almost useless. ;-)
Similar Threads - Motor screw stripped Forum Date
Professional Motor screw stripped, how do I get it out? Phantom 3 Help Aug 18, 2015
stripped motor screw. Phantom 1 Help Aug 16, 2013
DJI screw set, which are for the motors? Pro/Adv Discussion Jun 23, 2017
Used Loctite 242 (Blue) On Motor Mounting Screws Pro/Adv Discussion Dec 21, 2016
Small cracks in shell near motor mount screws Pro/Adv Discussion Jun 10, 2016
