I have a phantom 4 with a bad motor, the outside case is slowly sliding up exposing the windings. Is there a way to fix this or how do you replace the motor. I have a motor and I called DJI but they wanted me to send it in. Any help or suggestions.
i have the same issue, i noticed in flight that the drone jerked twice and could see it in the footage so i'm not sure it it hit something in the air. when i brought it down i noticed the outer shell was separating. It appears to be pressed in. Did you replace or repair the motor?ok I've taken the motor off and there is a c-clip but it is in place. I've taken the prop mounts off and there is no set screw, I've posted pic's and from what I can tell the shaft has splines and it looks like it might be pressed on. Is that possible?View attachment 65728 View attachment 65729 View attachment 65730
