Motor Problem?
Discussion in 'General Discussion' started by Rsa, Jul 27, 2015.
  1. Rsa
    Rsa
    I have a virtually new Vision + that I flew 2 times with no issues. When I went to attempt a third flight the next day a problem occurred. When I activate the quad for flight all the props begin to spin in standby mode. Then one of the props cuts out for a split second. It begins to do this continuously. Does anyone have a suggestion on what I can check?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Are you or were you using prop guards?
  3. 750r
    Pa, USA
    Are the lights on that arm doing anything when the motor acts up ? Pop her open look for a weak joint .
    Welcome to the forum .....
  4. RoyVa
    Virginia
    Have you completed any of the calibrations for the RC or IMU as well as the compass calibration?
  5. Rsa
    Rsa
    Yes, I am using prop guards. I even loosened the screws to make sure nothing was binding.
  6. Rsa
    Rsa
    I always do the compass calibration each time. Doesn't take long and good habit to get into I'm told.
    Not sure if I did the other calibrations a few weeks ago when I first opened it and updated the firmware.
  7. Rsa
    Rsa
    Thanks. Lights are normal. I guess I'll take a look inside for something loose.
Similar Threads - Motor Problem Forum Date
Yaw motor replacement problems Phantom 4 Help Jul 7, 2017
Problem with Gimbal Yaw Motor Phantom 4 Pro Help Jun 29, 2017
Problem following ESC and motor replacement Phantom 2 Help May 12, 2017
Standard Motor problem Phantom 3 Help Apr 25, 2017
Gimbal yaw motor problem Phantom 4 Help Mar 3, 2017
