- Joined
- Dec 24, 2015
- Messages
- 2
- Reaction score
- 0
- Age
- 40
Hello everyone,
I recently purchased a new S3 and I've had it for 3 weeks. Everything was working fine until I flew it during a bit of wind and had a rough landing. One of the motors rear silver ccw was still spinning when I picked it up from the ground and the propeller was caught. This prevented the motor from completing a full gyration and as a result damaged the motor where it needed to be replaced since it did not spin correctly for lift off.
I recently replaced the motor with a 2312 V2 rather than the 2312a (I read the only difference is the shock prevention and not performance, so it should be able to take off) I will replace once I get home from a trip. I spliced the wires and soldered them together and the motor worked perfectly fine. However, when I attempted to lift off, the black rear cw motor did not sping as quickly and prevented from take off. I turned the S3 off and brought it back home to assess. After bringing home, I updated the firmware and restarted. I re-calibrated the S3 and now, the front black cw motor does the same thing while all other motors are spinning normally.
Do you think its a calibration problem if all motors have the ability to gyrate normally? Is it the ESC board? Should I replace all motors?
Please help!
T
Please help!
T
