Motor Failure?
Discussion in 'Pro/Adv Discussion' started by kmhanson, Apr 14, 2016.
  1. kmhanson
    I lost my drone in a crash recently. I've uploaded the log files to healthy drones and I can find no anomalies. I was flying back to the home location about 100' high and about 10' offshore of the beach. I had just over 30% battery left and it was only about 1000' away from me. Then it just tumbled out of the sky. It fell in the surf and I never found it.
    After watching the video over and over and in slo-mo, it appears to me that the forward right motor failed. The drone started tumbling in that direction and you can see in several frames that the prop does not appear to be turning under power.
    I thought I'd post and get input from the community. I am planning on opening a support ticket with DJI and see if they agree that it was a mechanical failure.
    Thanks!
  2. N017RW
    Palm Beach Co.- FL
    More likely an ESC failure or connection than the motor.
    The motor has no moving parts other than bearings.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Or maybe you lost a prop?
  4. kmhanson
    I tightened the props just before the flight. Also, the prop that's visible in the video is attached through the entire crash sequence.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Right. It's the other three I was wondering about.
    Since you don't have the bird, DJI probably won't do anything other than offer you X% off a new bird. Even with the support of this community, there's really no telling what actually happened.
  6. kmhanson
    It started tumbling to the front right which leads me to conclude the other props were still attached and the motors functioning.
    Thanks for your input. I'm opening a ticket with DJI.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Okay. Please let us know how you make out.
  8. Brencade
    Ohio
    I just had an ESC error occur on mine a few days ago. Would not let me arm the motors after trying everything under the sun. Fell from the sky and said satellite off error, motor obstructed. The thing was about 30 ft away when all this happened after about a mile and half trip over the river. No serious damage. Sounds similar. I opened a ticket and have already returned mine, which fortunately was close to home when it happened. DJI acted quick so I was happy. Good luck
  9. Phantom751874
    Seemed so close to shore like it would have been easy to locate?
Similar Threads - Motor Failure Forum Date
Quad drop out of the sky from motor failure? How many have had this happen? General Discussion Jul 5, 2017
Phantom 3 standard - motor change failure Standard Mar 25, 2017
Phantom 4 Firmware Failure. Motor not work Phantom 4 Discussion Nov 7, 2016
P3 Professional Motor Failure, I am lucky it made it home in one piece. Pro/Adv Discussion Jul 5, 2016
Airborne Motors and Motherboard Failure Pro/Adv Discussion Apr 20, 2016
