Memory Card Files
Discussion in 'Pro/Adv Discussion' started by 0000edgar0000, Dec 10, 2015.
  1. 0000edgar0000
    Are there any files required to keep in the micro sd card? I cleaned the memory card and erased the files i used to upgrade the drone. Will that make the p3 lose the update? I thought once you uploaded the file it saves it to the internal memory but want to double check. Thanks!
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Nope. It's fine to clear it.
  3. Meta4
    Meta4 Moderator
    Staff Member
    Fly away with a clean card and enjoy the Phantom.
    Once the update's done, that's it - no more need for the update file.
  4. alokbhargava
    San Francisco, CA
    It was recommended to keep the previous update as it had battery update too. It was useful when you insert a new battery.
Similar Threads - Memory Card Files Forum Date
Professional PP3 firmware update won't let me drag files to memory card Phantom 3 Help Sep 24, 2015
64gb Memory Card General Discussion Dec 24, 2017
Memory Card Empty Message Pro/Adv Discussion Nov 22, 2017
Need advice on drone/ memory card found under water. Lost and Found Jun 30, 2017
New Phantom 3 Standard with video already on memory card Standard Jun 19, 2017
