MC Data Error when trying to enter flight data mode
Discussion in 'Pro/Adv Discussion' started by Sotiris Boutsis, Mar 7, 2016.
  1. Sotiris Boutsis
    I am trying to enter Flight Data mode to get the .DAT files. I am doing all steps as per instructions powering the TX then the P3 and going into Advanced settings in the GoApp. When choosing Enter flight data mode I am getting an "MC Data Error" message and then the yellow window saying that I am in Flight Data mode but after connecting my P3 to my Mac it is not connected.
    I never had any MC Data Error warning as long as I have the Phantom. Any ideas why is this happening?
  2. Raini
    Can you try the SD-card directly connected to your Mac?
  3. Sotiris Boutsis
    Don't think I can get the internal SD card out without tearing apart the bird.
  4. Raini
    That's right. As stated in other threads on the same subject the (internal) SD-card can cause this problem and one of the solution is to replace it. Otherwise your DJI-dealer has to repair it.
  5. Sotiris Boutsis
    I know this but from what I have read when the internal SD card is causing problems others are getting this error continuously even during flight. I am not getting any error message while flying or any other time which means that the data are recorded in the MC card. The only time I am getting MC Data Error message is momentarily when I am in the Advanced Settings and getting into data transfer mode. I am getting the error message for 2-3 secs and then the drone is going into data transfer mode but there is no drive appearing in my computer.
  6. BudWalker
    Santa Margarita, Ca
    The "MC Data ERROR" is normal when trying to retrieve when in Flight Data mode. The problem you're having is that connecting to a Mac requires some special steps. I'm not a Mac person but this might show you what you need to know.
    Professional - Downloading flight data using a Mac.
  7. Sotiris Boutsis
    BudWalker you are the man. Thanks for that.
  8. madeinengland
    Marlborough uk
    When I first tried retreiving data files I noticed the MC Data error message for a few seconds then it changed to flight data mode.
    But it took several seconds about 20 before it recognised the drive in fact it was quite worrying because the windows screen cleared
    I just waited and the data files appeared.I haven't tried formatting the internal memory card yet or to delete old data files.
    At the moment the disc is only half full.I'll worry about that when the time comes.
    Hope this has been reassuring.
    Cheers for now
    Ray
Similar Threads - Data Error trying Forum Date
Compass error and can't calibrate also no data received between RC and gimbal Phantom 4 Pro Help May 19, 2017
Professional Main controller data error p3a Phantom 3 Help Apr 8, 2017
P4P-Main Controller Data Error Phantom 4 Pro Help Apr 2, 2017
Main Controller Data Error on P3A Pro/Adv Discussion Feb 18, 2017
Advanced Main Controller Data error Phantom 3 Help Dec 19, 2016
