MC Data Error - Acccelerometer Failed : after a crash
Discussion in 'Pro/Adv Discussion' started by la_panza, Aug 30, 2015.
  1. la_panza
    Hello, I hit a Tree and had a crash, it seemed not to be a catastrophic one, the Phantom 3 pro fell on a meadow, only the gimbal connector was pulled out..
    After recionecting the Giimbal I have red-yellow-green quick LED sequence, the app reports "MC Data Error", the Overall Status page reports "accelerometer failed - IMU Calibration required"
    I tried to calibrate the IMU, at mid calibration it said an unknown error occurred, now I'm not able to find a way to try to calibrate again, simply can't find the command on the APP, where should it be?
    Back Home I removed the shell, in search of some broken wire or connector.. everything seems to be in order, where would I find the accelerometer, just for a visual check? I cant believe that a Crash is able to break an electronic component,...
  2. Jbundy63
    Someone on here posted a few weeks ago the the accelerometer has a possibility to get stuck in a crash or impact and they also showed how to fix it, I think they tapped it in a certain place. Maybe someone can find it and post it for you.
  3. Gnawtts
    ^ This absolutely works. I crashed mine into a wall, got the MC error, and did the accelerometer tap/reset and an IMU calibration - 100% fixed and flyable again.
    If you want to verify it's your accelerometer that's messed up and causing the MC error, look in your sensor values. If the accelerometer's MOD value is way out of range, that means you need to do this fix.
    Side note of caution: Just be careful taking the shell apart. DJI put these clip things in there to hold the two shell halves together, and it's a real feat to get it apart without breaking anything. But go slow and be cautious, and you'll be fine.
    Jbundy63 likes this.
  4. la_panza
    please see the photo attached... excuse me if it's rotated by 90° :)
    mod is quite High as you can see, but I really don't know what's the normal range...
    wher is physically the device to "tap"? can you please explain with some more detail what I should do?
  5. Oso
    Oso
    Western US
    Gyroscope Mod should be around 0.00
    Acceleration Mod should be around 1.00
    Compass Mod 1400-1600
    I think a little whack might do the trick, but it's up to you.
    JoBe and Jbundy63 like this.
  6. la_panza
    Yes, that's what I did, I simply dropped the drone on the table on its arms,. from 20 centimeter high.. ad it did work!! thanks everybody for these hints...
Similar Threads - Data Error Acccelerometer Forum Date
Professional Main controller data error Phantom 3 Help Dec 10, 2017
Main controller data error. Solved!!!! Standard Nov 13, 2017
Compass error and can't calibrate also no data received between RC and gimbal Phantom 4 Pro Help May 19, 2017
Professional Main controller data error p3a Phantom 3 Help Apr 8, 2017
P4P-Main Controller Data Error Phantom 4 Pro Help Apr 2, 2017
