Maybe dyeing props black was a mistake
Discussion in 'General Discussion' started by Ezookiel, Mar 26, 2015.
  1. Ezookiel
    Canberra Australia
    The photo doesn't do justice to just how invisible the black ones are to the naked eye.
    The red ones at the front you can see quite clearly the outline of them - even in the photo; , but even sitting at idle speed the black ones are impossible to see at most angles.
    Going to make hand-catching just that little bit more exciting LOL.
  2. landmannnn
    Coventry and Limoges
    red is better, doesn't show the blood!
    Jack Ley likes this.
  3. Happyflyer
    Cold, Cold, Michigan
    White, black, green, purple, orange, or blue, should not make any difference in hand catching if done correctly. You should be looking at the spot on the landing leg where you are going to do the grab and not the rotor or prop.
  4. Hughie
    Leeds, United Kingdom
    And dont worry because you can only make a mistake once. After that your fingers will be trimmed to correct length :D
    Brent10 likes this.
  5. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    :lol: Ya killin me dude !
  6. Ezookiel
    Canberra Australia
    I was being facetious with the "going to make hand-catching ... more exciting" comment. I wasn't serious.
    But I got a good laugh from the replies.
    Funnily enough, I took that shot as I was running a battery down by sitting it there idling, and reached under it to hold it down so I could rev it a little more, and had just the tiniest misjudge and the tiniest touch from the props, very literally just barely felt them. A few moments later I went to do something and there was blood on my fingertips. Amazed they'd drawn blood, I start cleaning my fingers to find which one is bleeding, and couldn't find any injury at all. That didn't surprise me, but I kept squeezing them anyway, as it seemed the only possibility.
    Still couldn't find a mark on myself. Put it down to the nick must have sealed up already, when a few minutes later my daughter said, "Do you know your cheek is bleeding?"
    I'd cut a nick on a mole while shaving and it had bled down my face, and I'd just spent ages trying to find a cut on my fingers instead.
  7. Happyflyer
    That's a good one.
    So instead of cutting your fingers off, you cut you nose off! This IS getting funny...... :lol:
  8. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    ;) OK if ya say so! :lol:
    Dem moles do bleed bad ! Got em too :lol:
  9. p fandango
    Coventry, UK
    please be very careful, they do bite (& i'm now using carbon blades lol)
    [​IMG]
  10. IflyinWY
    Where the deer and the antelope play
    Well the thread kept getting funnier and funnier until p fandango shared the pic of his arm customized by the carbon fiber props.
    I'm still kinda laughing though. :lol:
  11. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    I'm looking for translucent props so I can be stealthy! o_O
  12. Ezookiel
    Canberra Australia
    Ouch to the bites.
    And people mock propguards. I completely screwed up my judgement of how far behind a tree I was as I flew behind it the other day, and flew straight through the branches of it, and came out unscathed on the other side. That wouldn't have happened if I'd had no propguards on.
    Pretty sure propguards would have stopped those bite marks above too.
    If you can't find transluscent ones LuvmyTJ, then dyed black is the next best thing. You see straight through them.
    I must say, four big white circles sure helped with orientation when it was at full forward tilt going like the clappers, you always knew when it was coming back your way, as the 4x big white blurs were very visible. 2 invisible black ones, and 2 much less visible dark red ones, just don't give that instantly visible orientation reassurance - but they sure look cooler when it's stopped :)
  13. LuvMyTJ
    Staff Member
    Yeah, I dyed mine red & blue. Makes them easier to see and orientate.
Similar Threads - Maybe dyeing props Forum Date
Limited to 50m/30m, logged in; maybe due to split data in DJI Go? Pro/Adv Discussion Aug 11, 2017
Phantom 2v needs cost effective gimble, Chinese gimble maybe? Any ideas? General Discussion Jul 24, 2017
Maybe Silly Question.. or not: Re: 107 Cert. General Discussion Jul 5, 2017
Battery query solved.....maybe ,but now this ! Other DJI Multi-Rotors Jun 20, 2017
maybe not the place , but I'll ask anyhoo..... General Discussion Jun 20, 2017
