maybe a silly question
Discussion in 'Phantom 2 Vision + Discussion' started by hardtail, Sep 20, 2015.
  1. hardtail
    Hi im off to wales soon and will be going up snowdon mountain and ill be taking my p2 ,i was thinking today if it would be an issue if i flew over the summit edge or across a valley for some rising shots as the height from ground level would be way over the max altitude set limit and i had a funny feeling it may want to decend to the limited altitude or would it take my home point at the summit as the zero .
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The Phantom thinks the take off point is the ground. If you descend below that point, your current altitude will then be negative. Your Phantom will not auto descend when flying over the edge though. It won't even know you flew over the edge.
  3. hardtail
    thanks for that yes it was the negative height i was worrying about
  4. MapMaker53
    Long Island, NY
    Make sure you have the top of your wifi unit angle so that it is pointing at the Phantom when it is below your level or you may lose the connection.
Similar Threads - maybe silly question Forum Date
Maybe Silly Question.. or not: Re: 107 Cert. General Discussion Jul 5, 2017
Silly question maybe Off Topic Nov 6, 2016
Probably a silly question, but maybe not Phantom 2 Vision Discussion Oct 23, 2013
P3S - Maybe a paperweight? Standard Friday at 10:01 AM
River man - trying to make it down the river to the lake, maybe next time. Photos and Video Nov 9, 2017
