Hello,
I am installing FPV on my phantom 2 with zenmuse. It looks like transmitter will not fit inside, so i will have to do it as on video by ThatHPI Guy
https://www.youtube.com/watch?v=TL8pqtEDuos
That way of mounting means that transmitter will be outside, hanging under-belly.
My question - I am totally not keen on having exposed circuit board outside, so close to the ground - without any protection. A wet grass, or anything of that sort - can damage the transmitter (Boscam 400mW). Right?
So, I wonder do you think I can spray the board with a polymer based paint, to protect it? to cover all soldered points, and all things on the board with a permanent seal? Would it make sense, or i would risk some problems?
Or - maybe you have a better solution to this problem? (or maybe i am just nuts and should not be worried?)
Many thanks, cheers!
Derek
Derek
