Maximum altitude setting
Discussion in 'Phantom FC40 Discussion' started by darwin-t, May 17, 2014.
  1. darwin-t
    Is the maximum altitude setting refer to "above sea level" or "height above the take off point"?
    Thanks.
  2. mb_guy
    Winnipeg, MB. Canada
    I have read that they are height above take off, same as the fail safe altitude.
  3. J.James
    Upstate NY
    yes its height above the take off point
  4. Davztrk
    Yes, relative to home point setting, when it flashes green many times, it has setting home point.
    If you reset home point, HP is relevant to there.
Similar Threads - Maximum altitude setting Forum Date
Maximum flight altitude reached... at 50 feet?? General Discussion Mar 26, 2017
Maximum flight altitude Phantom 4 Pro Discussion Mar 19, 2017
Maximum Altitude Limit Failed Phantom 4 Pro Discussion Jan 2, 2017
Maximum Altitude 22 Meters? General Discussion Oct 27, 2016
Maximum Range (Radius) and Altitude Phantom 4 Discussion Aug 4, 2016
