No matter what I set my altitude or distance to I get max distance and altitude have been reached well before what they have been set to
What is the max altitude and distance you're able to reach? Are you just seeing that message in DJI GO or is your Phantom actually being restricted?
This may be related to the oft posted app issue. Check to see you are still logged into the app, if so, try logging out and then back in. Some folk have had to delete the app and reinstall it again, and sign in to remove the limitations. If you do have to delete the app, don't forget to sync your flight records first, otherwise they may be lost.
He meant the common issue that's often posted about like this one:What is an oft posted app?
