Map Question
Hammond, La
While flying today I noticed the arrow in the map was not the same direction of the drone, is there a setting that I have wrong, I did calibrate the compass and had 10 satellites. Should it be in the same direction that the phantom is flying.
Your red paper plane icon should indicate the orientation of your Phantom but if the compass in your tablet/phone is poorly calibrated you get the signs that you've described.
Search google to find out how to calibrate the compass in your tablet.
A simple fix is: Rotate the iPhone/iPad until the direction matches the aircraft then it the lock heading /map button. I have had that happen a few times. Makes the flight very confusing looking at the map view.
cgarner1
